How to decode SSL Logs
arvind.kumar
Post by arvind.kumar » Fri Apr 20, 2018 10:39 pm
I compiled softether from the sources and enabled ssl logging using the flag, ENABLE_SSL_LOGGING, and setting SSL_LOGGING_DIRNAME. The vpnserver generates the ssl log files but most of the contents are encrypted. How to decrypt the ssl log files ?
Re: How to decode SSL Logs
Post by cedar » Mon Apr 23, 2018 9:51 am
This option is not for logging communications in the tunnel.
This is for debugging SSL communication.
