VPN Connection Sharing via Hotspot
Darth_Jimbo
Post by Darth_Jimbo » Fri May 11, 2018 10:31 am
Dear Softether-Team,
on my laptop I have a Softether VPN connection to my homeserver, which I share to my phone via the wifi-hotspot-function of Windows 10.
Since the Spring Creators Update (1803) this is not working anymore, because the VPN-adapter is not recognized as an ethernet connection an thus is not available to be shared via hotspot. (in other words: Open Settings-App >> Go to Network & Internet >> Open the Ethernet-tab on the left >> the VPN-Adapter is not there as it used to be before the update; the hotspot settings say, "We can't set up mobile hotspot because your PC doesn't have an Ethernet, Wi Fi or cellular data connection" as soon as a VPN connection is established) Is that a Softether or a Microsoft problem?
Thanks and Greetings
Jimbo
Edit: (Technical information)
Windows 10 Version 1803
Softether-Version 4.27 Build 9666
dealdeal
Re: VPN Connection Sharing via Hotspot
Post by dealdeal » Wed May 23, 2018 12:15 pm
Yeah, I have this problem also. I think softether developers need to update the drivers to fix it. or someone have other solution?
Post by thisjun » Tue Jun 12, 2018 7:26 am
SoftEther virtual NIC driver is no longer an Ethernet since build 9666.
Because Windows disconnect the mobile connection when the Ethernet is connected after 1803 update.
Darth_Jimbo
Post by Darth_Jimbo » Tue Jun 19, 2018 4:06 pm
Yes this LTE / 3G bothers me on another device, where I have no internet on ethernet (it's connected to a laser cutting machine) but as soon the cable is plugged, 3G will auto disconnect. They couldn't make a checkbox to turn that feature off, could they. But that's another story...
Anyway I don't use LTE / 3G connection on my VPN machine so this issue fixed in 9666 doesn't bother me. So am I assuming right, that the hotspot will work again with a version PRIOR build 9666??
Edit: I can answer this question by myself by simply trying it...
Darth_Jimbo
Post by Darth_Jimbo » Wed Jun 20, 2018 6:57 am
I'm afraid using an older version doesn't work, but I'm still figuring out whether it uses the old driver version (I suspect Windows auto-updates it)
I tried all of the hotspot freeware.
Problem is that they use the older Hosted Network API introduced in Win 8, which is deprecated since Win 10 as it was replaced with the Wifi Direct API.
The Hosted Network API requires a card and driver which support it (you may remember "Hosted network supported : No"). Most Win 10 drivers for wireless cards don't support it because Wifi Direct doesn't need it anymore.
That's a bummer.
Maybe there is another solution: In Windows 10 settings there is also a section for VPN connections. If it would be possible to share a built-in-VPN-connection via hotspot (never tried it) and if Softether may define it's connection as a VPN connection, then maybe it would work again...
But that needs testing, which I can't do...
Post by cedar » Fri Jul 06, 2018 4:17 am
Since this is a driver fix, in order to avoid the problem, it is necessary not only to lower the version of the client but also to re-make the virtual LAN card.
hisham315
Post by hisham315 » Tue Aug 07, 2018 12:59 pm
> LAN card.
could you tell us how to do that?
Post by cedar » Tue Aug 07, 2018 6:42 pm
Please delete current virtual NIC. And, creare new one.
hisham315
Post by hisham315 » Wed Aug 08, 2018 12:44 am
I'm sorry but is there anyway you could share a tutorial video or smth , I really need this to work .
Post by thisjun » Wed Sep 05, 2018 7:48 am
Please right-click of the NIC and select delete.
