i've softether installed and working since 2-3 years
this afternoon, i cant connect any more, in logs i see:
"2018-05-14 16:14:25.867 L2TP PPP Session [95.237.92.111:1701]: Acquiring the IP networking information such as subnet mask and the default gateway information from the DHCP server.
2018-05-14 16:14:30.872 L2TP PPP Session [95.237.92.111:1701]: Acquiring the networking information from the DHCP server failed. To accept a PPP session, you need to have a DHCP server. Make sure that a DHCP server is working normally in the Ethernet segment which the Virtual Hub belongs to. If you do not have a DHCP server, you can use the Virtual DHCP function of the SecureNAT on the Virtual Hub instead.
2018-05-14 16:14:31.197 L2TP PPP Session [95.237.92.111:1701]: The VPN Client sent a packet though an IP address of the VPN Client hasn't been determined.
2018-05-14 16:14:31.197 L2TP PPP Session [95.237.92.111:1701]: A PPP protocol error occurred, or the PPP session has been disconnected.
2018-05-14 16:14:31.311 [HUB "VPN"] Session "SID-MIATELLO.MAURO-[L2TP]-12": The session has been terminated. The statistical information is as follows: Total outgoing data size: 8322 bytes, Total incoming data size: 1442 bytes.
2018-05-14 16:14:31.332 Connection "CID-16" terminated by the cause "The VPN session has been deleted. It is possible that either the administrator disconnected the session or the connection from the client to the VPN Server has been disconnected." (code 11).
2018-05-14 16:14:31.332 Connection "CID-16" has been terminated.
2018-05-14 16:14:31.332 The connection with the client (IP address 95.237.92.111, Port number 1701) has been disconnected."
i've tried to reboot server, but it doesnt work
dhcp in my lan is ok
how is it possible that suddenly stop working?
what happens?
desperados
desperados
Re: Acquiring the networking information from the DHCP server failed
i've 2 dhcp server, the backup dhcp server is on the same server of softether, and it is a linux server
can this be a problem ?
desperados
using openvpn it works, using l2tp/ipsec doesn't
what the hell is happened ?
Do you enable the localbridge?
If so, is it tap mode?
