I'm configuring SoftEther via vpncmd. Lately, I added split tunnel functionality but now I have to "edit the static routing table to push" as you can see on the attached screenshot. What command do I have to use to set those settings with vpncmd?
Thanks
Michael
How can I edit the static routing table to push via vpncmd
ynusis
Re: How can I edit the static routing table to push via vpncmd
DhcpSet
You can see the online help by "DhcpSet /?" on vpncmd command line.
ynusis
