Good day!
May you help me configure onto Server on how can I disable internet usage on the part of VPN client when connected. And it resumes after disconnecting.
Thanks!
Block Internet on VPN Client when connected
Arjen
Re: Block Internet on VPN Client when connected
eddie brown wrote:
> I think you need to follow the procedure of manually configuring your net
> connection. Try to set the DNS leak protection. First, disconnect from the
> VPN and enable DNS leak protection if you have it. Others steps depend on
> your operative system. Think Google will help you.
Thank you for your prompt attention on this matter.
I'm not really an expert with this VPN,
what I want to know that if you can show me how can I do it with the Softether VPN Server?
Arjen
roberto wrote:
> To disable the VPN service open the "Switch Operation Mode" in
> the "Tools" menu.
> Click the "VPN Gate Service Settings" button the "Switch
> SoftEther VPN Client Operation Mode" screen.
> The "VPN Gate Service Control Panel" will appear. Uncheck the
> "Enable the VPN Gate Relay Service and join the VPN Gate Research as a
> Volunteer." and click the "OK" button.
> Your VPN Gate Relay Service is deactivated.
Good Day SoftEther!
Actually, my settings is already been uncheck or deactivated the "Enable the VPN Gate Relay Service and join the VPN Gate Research as a
> Volunteer." I did not enable it from the start I installed the SoftEther VPN Server.
> the "Tools" menu.
Good Day SoftEther!
Arjen
Is the access lists has something to do with this? How?
If you don't want to go to the internet via VPN, please delete default gateway address of client virtual NIC.
