Disable UDP Acceleration Linux Client
cmd wh0ami
Post by cmd wh0ami » Tue Jun 19, 2018 2:52 pm
Where is the command in vpncmd to disable UDP Acceleration in the Linux client? I didnt see it in Help or in AccountDetailSet
Trying to make MTU 1500 and VPN undetectable.
cmd wh0ami
Re: Disable UDP Acceleration Linux Client
Post by cmd wh0ami » Tue Jun 19, 2018 5:38 pm
The only way I was able to get it was to export client vpn config from Windows client and import them in Linux client..
Has anyone figured out how to do this same kind of fix for OpenVPN in SoftEther? Been reading about mssfix 1400 or mssfix 0 but I cant get any of them to change the MTU value on VPN detection sites.
cmd wh0ami
Post by cmd wh0ami » Thu Jun 21, 2018 6:49 pm
or edit it in vpnclient/vpn_client.config
Post by cedar » Fri Jul 06, 2018 4:25 am
The option to change NoUdpAcceleration is not yet implemented.
