This VPN Server has been the EASIEST server to setup WOW, but I have one issue, I have a iPhone 8+ and followed these instructions
went to Setting/VPN added a VPN gave the server name as the public IP I have, acct was let say iPhone@HomeVPN, RSA disabled Password I assigned to account and the Secret created, then send All traffic enabled and Proxy Off. I then get error The l2TP-VPN server did not respond try connecting ...
the document used is below
https://www.softether.org/4-docs/2-howt ... nt_Setting
Keith
Connection with iPhone 8+
Re: Connection with iPhone 8+
If you place the VPN server behind a NAT router, port forwarding is needed.
Please forward UDP/500 and UDP/4500 to the VPN server.
