Local Bridge for secondary Hub not working
mar788
Post by mar788 » Mon Jul 30, 2018 12:23 pm
I use an Ubuntu 16 LXC. I successfully built the local bridge for my primary HUB using the private IP in iptables postrouting (instead of Public VPS IP).
So far so good, everything works. Clients connect the VPN and surf the net.
Then I tried to local bridge also my secondary Hub, and there is not internet for clients of secondary HUB after they successfully connect to the VPN.
Can you tell me what's the problem ?
My main hub name is "VPN" . Tap device "soft"
My secondary hub name is "abc" . Tap device "abc"
mar788
Re: Local Bridge for secondary Hub not working
Post by mar788 » Mon Jul 30, 2018 12:25 pm
Other pictures.
Post by thisjun » Wed Sep 05, 2018 6:49 am
tap_soft netmask is 255.0.0.0. Is it right?
In iptable, to-source is the same IP address. Does it work?
