Hi!
I've made a patch for SoftEtherVPN v4.27-9668-beta (Stable) 29.05.2018 windows-x86_x64
Now you can assign a static MAC address to the user, just fill the user note with it XX-XX-XX-XX-XX-XX. If user note is empty or contains text <>17 symbols length it will work as usual and generate MAC address using build in SEVPN function.
You can download it here(SEVPN_static_MAC.zip):
https://www.dropbox.com/s/rcsfj2j8ntu44 ... C.zip?dl=0
Check attched files: readme.txt and Session.c for details.
By the way, If I add a line to account.c(and account.h) with new policy like "Use User Note as MAC address", what else should I modify to make it work?
Static MAC address for user patch
slim8020
slim8020
Re: Static MAC address for user patch
Unregistered users are unable to download attachments(readme.txt), so here it is:
STATIC MAC ADDRESS FOR USER PATCH(beta) 23.08.2018 by Slim8020
DISCLAIMER: Use at your own risk.
REQUIREMENTS: SoftEtherVPN v4.27-9668-beta (Stable) 29.05.2018 windows-x86_x64
DESCRIPTION:
INSTALLATION:
1. Stop SoftEther VPN Server service (Start->All Programs->SoftEther VPN Server->Configuration Tools->Services Running on this Computer);
2. Rename %program files%\SoftEther VPN Server\vpnserver_x64.exe (*) to vpnserver_x64.bak;
3. Copy patched vpnserver_x64.exe (*) to %program files%\SoftEther VPN Server\;
4. Start SoftEther VPN Server service (Start->All Programs->SoftEther VPN Server->Configuration Tools->Services Running on this Computer);
(*) - vpnserver.exe if you using x86 version.
SETTINGS:
Run SoftEther VPN Server Manager-> connect to your server-> manage your virtual hub->manage users->edit User->fill the user note with MAC XX-XX-XX-XX-XX-XX.
To avoid conflicts I recommend to set security policy:
Deny MAC Addresses Duplication = Enabled;
Maximum Number of MAC Addresses = 1;
SOURCE CODE:
If you want more details, please compare it with original source code lines №2344-2375: https://github.com/SoftEtherVPN/SoftEth ... on.c#L2344
PATCH CODE:
Session.c has modifed lines № 2344-2386:
DESCRIPTION:
INSTALLATION:
SETTINGS:
SOURCE CODE:
PATCH CODE:
AcLock(h);
USER *u = AcGetUser(h, username);
if (u != NULL && wcslen(u->Note) == 17) //check User Note
UCHAR strNote[19];
wcstombs(strNote, u->Note, 19);
sscanf( strNote, "%x-%x-%x-%x-%x-%x",&s->IpcMacAddress[0], &s->IpcMacAddress[1], &s->IpcMacAddress[2],&s->IpcMacAddress[3], &s->IpcMacAddress[4], &s->IpcMacAddress[5] ) ;
}else{
Hash(hash, tmp, StrLen(tmp), true);
s->IpcMacAddress[0] = 0xCA;
s->IpcMacAddress[1] = hash[1];
s->IpcMacAddress[2] = hash[2];
s->IpcMacAddress[3] = hash[3];
s->IpcMacAddress[4] = hash[4];
s->IpcMacAddress[5] = hash[5];
ReleaseUser(u);
MacToStr(tmp, sizeof(tmp), s->IpcMacAddress);
Debug("MAC Address for IPC: %s\n", tmp);
AcUnlock(h);
return s;
// Check whether the specified MAC address is IPC address
bool IsIpcMacAddress(UCHAR *mac)
// Validate arguments
if (mac == NULL)
return false;
//if (mac[0] == 0xCA)
return true;
//return false;-
PiStAcIuS
God bless you!!!
I was searching for this thing for month. Thank you very much!
You´ve made my day :D
ashar2017
Hi
first of all thanks for making patch.
i am facing issue, every time i connect the client. in server MAC address last 2 characters change and due to this my external dhcp server takes this client as new , i have attached every possible screenshot in one file.
I hope someone guide me what i am doing wrong.
i installed the archive version v4.27-9668-beta (Stable) 29.05.2018
Regards,
Regards,
mjunior10
FUNCIONOU! MUITO OBRIGADO!
