How to setup softether
Sunil Kumar
Post by Sunil Kumar » Sat Aug 25, 2018 10:19 am
I am trying to setup multiple sites and access through softether but its not accessible
Sunil Kumar
Post by Sunil Kumar » Sun Aug 26, 2018 1:41 am
Hi Guys
Please help me to setup SoftEther VPN on my sites.
Re: How to setup softether
Post by cedar » Sun Aug 26, 2018 2:05 am
sammartin8935
Post by sammartin8935 » Thu Aug 30, 2018 8:30 am
I am assuming you are using Windows. If so then follow these steps and you will be good to go.
Download SoftEther VPN client for Windows.
Start Installation.
Click “Next” (1).
Choose “SoftEther VPN Client” (2) and click “Next” (3).
To continue to install SoftEther VPN on Windows check “I agree to the end user License Agreement” (4) box and click “Next” (5).
On the “Important notice” screen click “Next” (6).
Choose the directory to install the software and click “Next” (7).
Click “Next” (8). The Installation process will start.
After the installation process is finished click “Finish” (9).
Launch the SoftEther VPN Client Manager.
In the main screen click “Add VPN connection” (10).
A message box will appear asking if you want to create a Virtual Network Adapter. Click “Yes” (11).
In the “New VPN Connection Setting Properties” window enter the following parameters:
Setting Name type (12): CactusVPN (or any other name you want).
Host Name (13): Add IP address of the desired server (You can find all the available servers in the package details in the Client area.).
Port Number (14): 443 (you can also use port 992, 1194, or 5555).
Virtual Hub Name (15): Select Ivacy from the drop-down menu.
Auth Type (16): Select Radius or NT Domain Authentication.
Username (17): VPN username.
Password (18): VPN password.
You can find them in the client area on our website, by going to your package. Make sure you use your VPN username and password and NOT the client area credentials (What is the difference?).
Click “OK” (19) to create a VPN connection.
To connect to VPN right click on your VPN connection and click “Connect” (20).
To disconnect SoftEther VPN on Windows right-click on your VPN connection and click “Disconnect” (21).
