[Solved] epass2003 can not run with Software VPN Client 4.20
trungnt
Hi all,
I have just bought Feitian PKI Epass 2003 token usb, I downloaded driver and application software this link: http://download.ftsafe.com/files/ePass/ ... 151116.zip.
I can write cert and key to epass2003 tokent usb. When I create new connect from SoftEther VPN Client Manager, I can show cert and key from the token usb, but I use the token to connect VPN server from SoftEther VPN Client Manager but error (As you can see attatched file).
Please, help me.
Please, help me.
trungnt
Re: epass2003 can not run with Software VPN Client 4.20
trungnt wrote:
> Hi all,
> Please, help me.
Hi all,
I think SoftEther VPN Client not support or mistake
@admin, please help me.
> Hi all,
> Please, help me.
Hi all,
trungnt
trungnt
Nobody helps me!
Please confirm that the RSA key size of cert is 1024bit.
trungnt
I don't remember beacause long time ago, I didn't do it. What is happing with 1024bit or 2048bit.
trungnt
> or 2048bit.
Nobody helps me!
> or 2048bit.
Nobody helps me!
http://www.softether.org/5-download/history
> SoftEther VPN 4.22 Build 9634 Beta (October 27, 2016)
> Added the support for 4096 bits RSA authentication with smart cards.
trungnt
Thank you for your reply,
- With Software VPN Client is version 4.20, you have to create RSA key size of cert which is 1024bit, it's running.
- With Software VPN Client is version 4.22, you can create RSA key size of cert which is 2048bit, it's running, too
Thank you so much!
Thank you so much!
