Installation guide for linux client
linuxgeek
Post by linuxgeek » Wed Sep 05, 2018 7:43 am
I have been trying to find a guide on how to install the softether vpn client on linux. Could someone point me where to find it? Is there anyone who could post a guide on how to install it on linux? Any help is greatly appreciated. Thank you.
fenice
Re: Installation guide for linux client
Post by fenice » Wed Sep 05, 2018 8:10 am
There is an install script in the download file, did you run that?
Regards
Bill
linuxgeek
Post by linuxgeek » Thu Sep 06, 2018 4:47 pm
You mean I don't have to run the "make" or compile? I just have to run the install script? I will try that, Thank you.
fenice
Post by fenice » Thu Sep 06, 2018 4:50 pm
I assume that's the case but just for info, I don't use that piece of SoftetherVPN. Good luck and let us know how you net on.
Regards
Bill
linuxgeek
Post by linuxgeek » Thu Sep 06, 2018 6:18 pm
Everything went fine. It is now connected to the server. However one question, how do we know the hostname of the client connected in the server, or what is the ip address assign by the server to the client? Is there a list of clients in the server that we can see it? I check the virtual card created in the linux client by using ifconfig, but there is no ip address assigned in the virtual nic. Below are the info that ifconfig showed:
vpn_vpn Link encap:Ethernet HWaddr 5E:38:71:3E:EC:39
inet6 addr: fe80::5c38:71ff:fe3e:ec39/64 Scope:Link
RX packets:333137 errors:0 dropped:0 overruns:0 frame:0
TX packets:43147 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:500
RX bytes:65682923 (62.6 MiB) TX bytes:3572538 (3.4 MiB)
Below the connection status:
VPN Client>AccountList
AccountList command - Get List of VPN Connection Settings
Item |Value
VPN Connection Setting Name |evovpn
Status |Connected
VPN Server Hostname |192.168.200.212:5555 (Direct TCP/IP Connection)
Virtual Hub |evo_vpn
Virtual Network Adapter Name|VPN
** I have to move this discussion on this tread: viewtopic.php?f=7&t=3226
Post by thisjun » Thu Oct 04, 2018 5:54 am
You can know the hostname of the client in the server log.
IP address should be assigned by traditional way (static or DHCP).
cmd wh0ami
Post by cmd wh0ami » Thu Oct 04, 2018 12:46 pm
Where is the install script? All I see is a Makefile
whoami@ubuntu:~$ tar xzvf softether-vpnclient*
vpnclient/
vpnclient/Makefile
vpnclient/.install.sh
vpnclient/ReadMeFirst_License.txt
vpnclient/Authors.txt
vpnclient/ReadMeFirst_Important_Notices_ja.txt
vpnclient/ReadMeFirst_Important_Notices_en.txt
vpnclient/ReadMeFirst_Important_Notices_cn.txt
vpnclient/code/
vpnclient/code/vpnclient.a
vpnclient/code/vpncmd.a
vpnclient/lib/
vpnclient/lib/libcharset.a
vpnclient/lib/libcrypto.a
vpnclient/lib/libedit.a
vpnclient/lib/libiconv.a
vpnclient/lib/libintelaes.a
vpnclient/lib/libncurses.a
vpnclient/lib/libssl.a
vpnclient/lib/libz.a
vpnclient/lib/License.txt
vpnclient/hamcore.se2
whoami@ubuntu:~$ cd vpnclient
whoami@ubuntu:~/vpnclient$ ls
Authors.txt  hamcore.se2  Makefile                              ReadMeFirst_Important_Notices_en.txt  ReadMeFirst_License.txt
code         lib          ReadMeFirst_Important_Notices_cn.txt  ReadMeFirst_Important_Notices_ja.txt
I guess you could consider the Makefile a install script... But it didn't do everything I needed it to do. I still had to do some routing myself for the virtual NIC.
Post by thisjun » Thu Oct 18, 2018 6:37 am
It seems there is "vpnclient/.install.sh".
