Good evening!. What I would like to say is that "Increasing bandwidth" is not the thing that you would get it by clicking some buttons or enabling some options that are a part of this or that program. Usually it depends on a lot of factories, your ISP policy, for instance. with that said, I would like to suggest that you double check about the speed values that you got and let's know about it. Do it three, four, five times to make sure and get back to here to see what create people suggest on this topic (:.
Good luck (:.
Looking for a way to increase the VPN limited bandwidth...
raafat
Re: Looking for a way to increase the VPN limited bandwidth.
SoftEther VPN doesn't limit bandwidth.
