Disable SSL-VPN
0xc000007e
Disable SSL-VPN
Post by 0xc000007e » Thu Oct 04, 2018 3:37 am
I just want to know how to disable it on SoftEther VPN Server and nothing in the user interface or doing a Google Search yields any answers.
Please tell me how!
I noticed some hosts on VPN Gate had SSL-VPN disabled and I want to know how.
Re: Disable SSL-VPN
Post by thisjun » Wed Oct 17, 2018 8:38 am
Please don't forward SSL port.
0xc000007e
Re: Disable SSL-VPN
Post by 0xc000007e » Fri Oct 19, 2018 7:18 am
What is the port?
Re: Disable SSL-VPN
Post by thisjun » Thu Nov 01, 2018 7:43 am
0xc000007e
Re: Disable SSL-VPN
Post by 0xc000007e » Mon Nov 05, 2018 6:22 am
Oh, I meant what port number it uses. It turns out that on the front page of SoftEther, it says "Ethernet over HTTPS" which obviously uses port 443.
I run a web server on port 443 so I don't have to worry about blocking that port. Thanks for responding anyway!
Re: Disable SSL-VPN
Post by thisjun » Thu Nov 15, 2018 8:25 am
You can disable the listening port here.
https://www.softether.org/4-docs/1-manu ... ener_Ports
Please do not disable all ports.
Or, you can't connect with Sever Manager.
