hey all,
I've setup a Softether VPN server and generated a openvpn profile using the tool on Softether. every time I try to connect from the OpenVPN android app using the profile and a user I created I keep getting a Auth Failed message on the client, and the server has this log. I can't figure out the issue because according to the log it looks like it does authenticate. Please let me know if you have any idea what's going on! Thank you!! P.S. I edited all external IP's.
2018-10-14 21:08:43.487 OpenVPN Session 6 (69.69.69.69:42982 -> 192.168.1.6:1194): A new session is created. Protocol: UDP
2018-10-14 21:08:43.487 OpenVPN Session 6 (69.69.69.69:42982 -> 192.168.1.6:1194) Channel 0: A new channel is created.
2018-10-14 21:08:43.528 OpenVPN Session 6 (69.69.69.69:42982 -> 192.168.1.6:1194) Channel 0: Option Strings Received: "V4,dev-type tun,link-mtu 1557,tun-mtu 1500,proto UDPv4,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-client"
2018-10-14 21:08:43.528 OpenVPN Session 6 (69.69.69.69:42982 -> 192.168.1.6:1194) Channel 0: Option Strings to Send: "V4,dev-type tun,link-mtu 1557,tun-mtu 1500,proto UDPv4,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-server"
2018-10-14 21:08:43.639 On the TCP Listener (Port 0), a Client (IP address 69.69.69.69, Host name "ip69-69-69-69.ph.ph.cox.net", Port number 42982) has connected.
2018-10-14 21:08:43.639 For the client (IP address: 69.69.69.69, host name: "ip69-69-69-69.ph.ph.cox.net", port number: 42982), connection "CID-43-604BD5D1A5" has been created.
2018-10-14 21:08:43.639 SSL communication for connection "CID-43-604BD5D1A5" has been started. The encryption algorithm name is "(null)".
2018-10-14 21:08:43.642 [HUB "VPN"] The connection "CID-43-604BD5D1A5" (IP address: 69.69.69.69, Host name: ip69-69-69-69.ph.ph.cox.net, Port number: 42982, Client name: "OpenVPN Client", Version: 4.28, Build: 9669) is attempting to connect to the Virtual Hub. The auth type provided is "External server authentication" and the user name is "note9".
2018-10-14 21:08:43.642 [HUB "VPN"] Connection "CID-43-604BD5D1A5": Successfully authenticated as user "note9".
2018-10-14 21:08:43.643 [HUB "VPN"] Connection "CID-43-604BD5D1A5": The new session "SID-NOTE9-[OPENVPN_L3]-6" has been created. (IP address: 69.69.69.69, Port number: 42982, Physical underlying protocol: "Legacy VPN - OPENVPN_L3")
2018-10-14 21:08:43.643 [HUB "VPN"] Session "SID-NOTE9-[OPENVPN_L3]-6": The parameter has been set. Max number of TCP connections: 1, Use of encryption: Yes, Use of compression: No, Use of Half duplex communication: No, Timeout: 20 seconds.
2018-10-14 21:08:43.645 [HUB "VPN"] Session "SID-NOTE9-[OPENVPN_L3]-6": VPN Client details: (Client product name: "OpenVPN Client", Client version: 428, Client build number: 9669, Server product name: "SoftEther VPN Server (64 bit)", Server version: 428, Server build number: 9669, Client OS name: "OpenVPN Client", Client OS version: "-", Client product ID: "-", Client host name: "", Client IP address: "69.69.69.69", Client port number: 42982, Server host name: "192.168.1.6", Server IP address: "192.168.1.6", Server port number: 1194, Proxy host name: "", Proxy IP address: "0.0.0.0", Proxy port number: 0, Virtual Hub name: "VPN", Client unique ID: "E9B9276E4072A030307EB33EBF704E0B")
2018-10-14 21:08:48.648 OpenVPN Session 6 (69.69.69.69:42982 -> 192.168.1.6:1194) Channel 0: Acquiring an IP address from the DHCP server failed. To accept a PPP session, you need to have a DHCP server. Make sure that a DHCP server is working normally in the Ethernet segment which the Virtual Hub belongs to. If you do not have a DHCP server, you can use the Virtual DHCP function of the SecureNAT on the Virtual Hub instead.
2018-10-14 21:08:48.648 OpenVPN Session 6 (69.69.69.69:42982 -> 192.168.1.6:1194) Channel 0: Failed to connect a channel.
2018-10-14 21:08:48.905 [HUB "VPN"] Session "SID-NOTE9-[OPENVPN_L3]-6": The session has been terminated. The statistical information is as follows: Total outgoing data size: 0 bytes, Total incoming data size: 1276 bytes.
2018-10-14 21:08:48.931 Connection "CID-43-604BD5D1A5" terminated by the cause "The VPN session has been deleted. It is possible that either the administrator disconnected the session or the connection from the client to the VPN Server has been disconnected." (code 11).
2018-10-14 21:08:48.931 Connection "CID-43-604BD5D1A5" has been terminated.
2018-10-14 21:08:48.931 The connection with the client (IP address 69.69.69.69, Port number 42982) has been disconnected.
2018-10-14 21:09:13.697 OpenVPN Session 6 (69.69.69.69:42982 -> 192.168.1.6:1194): Deleting the session.
						OpenVPN Auth issue
				davidebeatrici
Re: OpenVPN Auth issue
In that case it's not an authentication issue, the OpenVPN client fails to connect because you don't have a DHCP server:
