[Android/iOS] Totally Free VPN - Easy VPN Gate Connector
I released a Free VPN app on Android based on VPN Gate list.
Tried to make it as simple as possible, recently updated with lots of improvements.
Hope it helps.
Android:
https://play.google.com/store/apps/deta ... llyfreevpn
iOS
https://itunes.apple.com/app/totally-fr ... 1046383684
Thank you.
Hope it helps.
Android:
iOS
Thank you.
Re: Totally Free VPN App on Android
just pushed out 1.6.0 with tcp/udp filter feature.
Thank you! This VPN app is very useful.
hello. i actually have a iOS version but you have to separately download an openvpn client to use it as it doesnt come with VPN built in.katemcguire877 wrote: ↑Thu Dec 06, 2018 3:09 pmwow! this is an excellent app. Can you also create one for ios devices? I will install this over my samsung phone but I also need one of these over my IPAD. Thanks! :)
https://itunes.apple.com/sg/app/totally ... 83684?mt=8
I haven't updated it for some time. let me know if you have any issues with it. thank you very much for using it!!! appreciate tons!
Re: [Android/iOS] Totally Free VPN - Easy VPN Gate Connector
just released version 1.7.1 on android with multiple fixes.
Wow, that is amazing. Works great. Thank You for the development and improving and sharing :)
Per aspera ad astra
Thank you for this app, it makes it more convenient especially for us dummies. I do want to ask if this app allows torrent file downloading? Appreciate your reply.
Cheers!
Cheers!
there shouldnt be a problem allowing torrent download.
i released a new version that filters away bad reputation servers. do upgrade and try. thank you!
THANKS FOR THE VPN
How is this different from the Easy ovpn app that's been around for years?
amazing app!!!
Hello all,
I have recently installed this onto my Android phone. I have a few queries which it would be great to get answered.
A little background first:
Thanks for your help!
- I have been living in China a couple of years and as you will know, am forced to use a vpn to access many sites (Google, YouTube, Twitter and Facebook being the main ones but there are many others that are blocked).
- Because I am in China, quite a few VPN apps are themselves blocked and will not work at all. I have had subscriptions to most of the big ones (Nord, Pure, Proton, Windscribe, Iron Socket etc) and most I have cancelled because they all stop working at some point (become targeted and blocked).
- ExpressVPN has been the most reliable, although even its servers have become blocked from time to time. Normal service is normally resumed within a week or two. However for the last three months or so, ExpressVPN has become almost unusable, with connections using its client never succeeding, causing me to resort to using their OpenVPN profiles and an OpenVPN client on both Android and Windows instead. Sadly, in the last few weeks, even their OpenVPN profiles will not connect and consequently, I am looking to dump ExpressVPN and have turned my attention to VPN Gate as a potential solution.
- It appears that only UDP connections succeed from here in China. I presume TCP is blocked but could someone confirm that? Certainly, I have not been able to connect to anything via TCP.
- When I select to see only available UDP servers, most times I am presented with only 3, 4 or 5 servers to choose from. The list is rarely much longer. Why is this, when there are clearly thousands of servers listed as UDP capable?
- If I use the OpenVPN client (without the Totally Free VPN app) I can choose one of the many profiles I have saved locally and very likely achieve a connection to one or more - yet they are not in the list presented above. Why is that?
- Usually, I find that I can only successfully connect to one or possibly two servers in this short list. The others will return a "Waiting for server reply". Why is this?
- I notice that there is a 'Pro' version of the app on the Play Store. What extra features / benefits does this provide?
To be honest, I read an article that claimed that free VPNs are usually not that safe, but I guess it's more aimed at the companies, which provide them worldwide, rather than users who create them themselves. Thanks, for sharing it, I'm a bit bummed out I didn't find it earlier. Recently I was searching for a cheap VPN provider, and I went with Surfshark (as it was the most affordable option I can find). I have to say I'm not mad at all that I invested a bit of money since they have features I didn't know about before, and now I find useful (such as ad-block).
thank you for this... will try it out
Just installed in an android device and it is fast and hassle-free. Thank you.
Are all the servers from VPNgate?
How often does it update the servers list?
There are a bit of ads but still thanks for the effort.
I download it, How to use Totally free VPN it looks simple and amazing.. But how can I connect? Do you have Tutorial for this? Please help..
hey thanks for the great job!
so never mentioned, all vpns are by vpngate??
and you have an filter-by-reputation thing, what is that reputation??
