I am living outside of Serbia and I need VPN for Serbia. I saw that that one exist but I can't find IP of the VPN server.
If somebody can helps me. What I must put in
Add VPN Connection
Host name ?
Virtual Hub name ?
Thank you very much.
Serbia
fenice
Re: Serbia
I'm not really sure I understand what you're asking but..... are you talking about using VPNgate or a commercial VPN service and why do you want a VPN in Serbia specifically?
triksi
Re: Serbia
I need VPN for Serbia because in that way I can see Serbian TV channels because I am living outside of Serbia.
I am talking about VPNgate.
When I open in software SoftEther - VPN Gate Public VPN Relay Servers - there is NOT server for VPN for Serbia and I can't choose anything from the list in the software.
Because of it I think that I must go in - Add VPN Connection and there are the fields
Add VPN Connection
Host name ?
Virtual Hub name ?
In the list of the VPN servers on the site VPN gate THERE IS also VPN for Serbia but I don't know what dates to put in the fields up.
Thank you
Add VPN Connection
Host name ?
Virtual Hub name ?
Thank you
sky59
Re: Serbia
Geopolitical control, i have tue same problem
You have to leave runnning vpn server in Serbia, orange pi zero is enough, i just tested it today, it is possible
So will use "softether cable" from your residence to serbia
