[Solved]Softether - Public IP address doesn't change
DDos
Post by DDos » Thu Nov 08, 2018 7:28 am
I'm using SoftEther, for Windows 64bits (W10 last update), has explained here : https://www.vpngate.net/en/howto_softether.aspx
According to the software, I'm well connected to distant gate, but when I'm looking at my IP on this page : https://www.vpngate.net/en/
I can see that it's not changing with or without SoftEther activated.
How can I proceed to make it work as expected ?
Thanks in advance for your help.
fenice
Re: Softether - Public IP address doesn't change
Post by fenice » Thu Nov 08, 2018 7:31 am
When you're connected to the VPN go to the folloring page in your browser and see what it says: http://www.whatsmyip.org/
Regards
Bill
DDos
Post by DDos » Thu Nov 08, 2018 7:35 am
Nevermind, I just used this option, and it fixed the problem. (cf picture)
hsawires
Post by hsawires » Fri Dec 07, 2018 12:51 pm
I had the same problem over my WiFi laptop.
I uninstall and reinstall the software and the adapter several times.
and it doesn't work for me.
