DNS LEAK TEST
Birdman2can
DNS LEAK TEST
Post by Birdman2can » Sun Nov 18, 2018 7:08 am
After I installed SoftEther VPN and established a connection through SoftEther VPN Gate Public Relay Servers, My IP Address showed me in Japan rather than BC, Canada. I ran a DNS Leak Test https://dnsleaktest.com/, Standard test immediatly exposed my IP address, the Extended test immediately exposed my IP address 6 out of 6 times. This is neither a private, nor secure situation and if there is no setting fix for this then I will have to look into a different VPN as a solution.
skyrise
Re: DNS LEAK TEST
Post by skyrise » Tue Nov 20, 2018 3:47 pm
I have exactly the same problem with DNS leak,after connecting the ip address changes, and the DNS remains unchanged
blackcat
Re: DNS LEAK TEST
Post by blackcat » Sat Mar 09, 2019 12:37 pm
Disable WebRTC in your browser, you can install an extension to do this:
https://addons.mozilla.org/en-US/firefo ... ak-shield/
Security Blog: https://hacker10.com
Whittle
Re: DNS LEAK TEST
Post by Whittle » Tue Apr 02, 2019 10:40 am
Does that extension itself open up the browser to some vulnerability?
fenice
Re: DNS LEAK TEST
Post by fenice » Tue Apr 02, 2019 1:05 pm
No, it doesn't and it wouldn't be of much use if it did. ;)
Regards
Bill
Jessica007
Re: DNS LEAK TEST
Post by Jessica007 » Mon May 06, 2019 8:33 pm
Damn..
It really can cause big problems with security issues...
Developers should fix it asap
centeredki69
Re: DNS LEAK TEST
Post by centeredki69 » Fri Jun 07, 2019 5:59 pm
If you are using windows. I found it to be a windows issue not SE. SE doesn't seem to override the DNS like other VPN apps do.
I connect to multi NordVPN servers via the built in Windows VPN client using IKEv2 and it also reveals my local DNS. However when I use the NordVPN software it overrides it and shows the remote NORD DNS servers. The OpenVPN client overrides them as well. There are many forums discussing this issue. Mainly in regard to employees connecting to corporate VPNs and not having access to remote office resources due to the client not connecting to the corporate DNS serves like should. Older Windows versions did not have this issue. With Windows 10 it started happening due to some update. I even noticed some win 7 PCs started having this issue.
FIX: On the machine with the issue search "Gpedit". In the Group Policy window please navigate to Computer Configuration -> Administrative Templates -> Network -> DNS Client and open "Turn off Multicast Name Resolution" Highlight->Edit->Enabled -> apply->OK Do the same for " turn off multi-homed named resolution" REBOOT PC
If you are using Active directory Domains. I believe this can be done via group policies on the AD server.
williamsongrand
Re: DNS LEAK TEST
Post by williamsongrand » Fri Aug 09, 2019 7:10 am
Have you tested on different tools? Because most of the time, it is tool error.
