How to access and configure SoftEther Server on AWS
ouki
Post by ouki » Mon Nov 19, 2018 1:13 am
I used the AWS marketplace SoftEther VPN server image and stood up a server with all default settings.
https://aws.amazon.com/marketplace/pp/B06WP3GT58
When I'm trying to connect to the VPN server using SoftEther VPN Server Manager, it says "connection to server failed"...
I could access the public IP over 443. It shows Forbidden.
I'm running the Manager on my Mac laptop. Here is the configuration. Per AWS marketplace, I used the EC2 instance ID as admin password.
I've tried everything and I could not connect to the VPN server. What am I missing?
Re: How to access and configure SoftEther Server on AWS
Post by thisjun » Tue Dec 11, 2018 2:14 am
I suspect your PC personal firewall blocks the VPN Server Manager communication.
