Unable to use Shared folders and web-service at the remote VPN server
Traungar
Post by Traungar » Wed Nov 21, 2018 3:00 pm
Dear colleagues, I strongly need your advice. Please assist
I like SoftEther, so it's very unfortunate that it's not working as expected.
I need a server with a remote access to:
- Shared folders,
- Web-service on port 28
So, I've installed SoftEther as a VPN - server and Client on the remote server side + installed the client onto the test machine.
Connecting - working: I can ping, I can access the shared folder, I can telnet to the 28th port.
But:
- Unstable connection speed (from 1 Mbit/s downto 0 - unpredictably)
- The App, which works with 28th port gives the connection error: "Required method 'POST' not supported" (HTTP 405)
(At the server side, the App is ok with physical IF and the same error - with the VPN client virtual IF)
So, the service is, by fact, unavailable.
SoftEther - all the settings are standard.
- VPN server,
- Secure NAN = on,
- Dynamic DNS = on
Please help.
Regards.
Traungar
Re: Unable to use Shared folders and web-service at the remote VPN server
Post by Traungar » Wed Nov 21, 2018 3:46 pm
UPD
Resolved by routing on the Client's machine.
route -p add 192.168.0.175 mask 255.255.255.255 192.168.30.1 metric 1
But it's not a clear way. Asking the developers to add some user-friendly mechanism.
Post by thisjun » Tue Dec 11, 2018 2:50 am
There is the function that pushes a route to a client.
