Ubuntu client => autostart => correct VLAN
carmamir
Post by carmamir » Sat Nov 24, 2018 7:21 pm
The vpnis working fine as long I run it manually.
I've tried to create the service, but for some reason the autostart for connection won't work unless I call it manually service vpn start
I've tried to create init.d but the same issue. Won't start unless I actually type in.
It is weird as everything else seems to be working, but only this is not.
Is it a bug, missing functionality or something else should be created or is there some special way for Ubuntu 18.04 ???
Re: Ubuntu client => autostart => correct VLAN
Post by thisjun » Tue Dec 11, 2018 3:11 am
Did you configure startup connection?
https://www.softether.org/4-docs/1-manu ... Connection
