i have this scenario:
Location1
SoftEther Vpn server
Windows server
Local network 10.31.70.x/24
Dhcp Enabled for both local network and VpnCode: Select all
Client1: 192.168.1.79/24
Hostname test1
SoftEther Vpn Client (Vpn ip 10.31.70.80)Code: Select all
Client2: 192.168.1.5/24
Hostname test2
SoftEther Vpn Client (Vpn ip 10.31.70.81)With the two clients connected, when i try to ping (or connect via windows shared folders) the other client in location2,
name resolution returns the Vpn ip address, so the client use the vpn connection instead of the local network.
How can i avoid this ?
Thanks
