Hello:
First of all, I've not found a similar problem in the forum, but if someone find something similar, please make me know.
Second, excuse my poor english.
Third, the problem is that I've this error messaje in the Dynamic DNS Function windows of one of my VPN servers (see attached file).
The full text says:
"Unable to trust the certificate provided by the destination server. The setting to always verify the server certificate is enabled in the VPN Connection Settings. Either register a root certificate that can be trusted or register a individual certificate."
The xxxxxxxxxx.vpnazure.net works well (slow), but the xxxxxxxxx.softether.net do not work at all.
Public iP from WAN side is OK.
Any clue....
Thanks a lot.
Dynamic DNS error message related to server certificates
lylinformatica
davidebeatrici
Re: Dynamic DNS error message related to server certificates
It's possible that your network's gateway is acting as a MiTM SSL proxy.
Are you the owner of the network?
Best regards,
Davide
Best regards,
Davide
lylinformatica
I don't know for sure, but I don't think so.
I'll check that in the firewall.
Thanks.
Thanks.
lylinformatica
Hello:
Nothing leads to a problem with an SSL Proxy that don't seem to exist.
The message says that there are untrusted certificates that dont allow to register the VPN server in Dynamic DNS service...
Any help?
Any help?
lylinformatica
Hello everyone:
More info for diagnostics...
Usin the public WAN ip WORKS!
Also using a no-ip.com domain (that points to public WAN ip).
But Dynamic DNS service from softether do not.
Thanks
Thanks
The DDNS service registry work on HTTPS.Nothing leads to a problem with an SSL Proxy that don't seem to exist.
So, if there is MITM, DNS registry fails.
