10.4 Build a PC-to-LAN Remote Access VPN access to Server
serak
Post by serak » Mon Oct 03, 2016 12:23 pm
I set up successfully this scenario and i can see all computers on net except VPN server self (no ping).
What should i set, to make acces on VPN Server? Is it something in VPN server settings or should i make some changes on system level?
Thanks for every advice.
serak
System - Linux Mint 17.3 64bit
ethernet chip realtek RT 1000Mbps
serak
Re: 10.4 Build a PC-to-LAN Remote Access VPN access to Serve
Post by serak » Wed Oct 05, 2016 11:52 am
I've added to system for ethernet connection another IP address, but it didn't helped.
Original ethernet IP 192.168.10.100
added 192.168.10.101
Both are visible, but from local net only. (again) For SoftEther client are both invisible.
As another try I plan to add in system another virtual net adapter. Maybe it helps.
Post by cedar » Wed Nov 02, 2016 5:56 am
Localbridging on Linux cannnot send packets to the host it self.
http://www.softether.org/4-docs/1-manua ... r_Mac_OS_X
Please try to add a new tap mode localbridge and assign another IP address for it.
