"Session invalidated: KEEPALIVE_TIMEOUT" or "Inactivity timeout (--ping-restart), restarting"
wshamroukh
Post by wshamroukh » Thu Jan 03, 2019 8:21 pm
Hello Team,
I am running Softether 4.28 Build 9669 on a Windows machine. I have an issue with my Android Clients.
When the Android clients are connected to WiFi and then connect to the VPN using "OpenVPN Connect" or "OpenVPN for Android" they connect fine and the connection stays up and everything is perfect.
However when the android device is only connected to 4G network only and then connect to VPN using "OpenVPN Connect" or "OpenVPN for Android" it connects successfully, however what happens is that it keeps disconnecting and i can never open any site. The following error is logged:
"OpenVPN for Android" error:
2019-01-03 23:05:57 [myvpnservername.softether.net] Inactivity timeout (--ping-restart), restarting
"OpenVPN Connect" error:
23:06:59.859 -- Session invalidated: KEEPALIVE_TIMEOUT
23:06:59.860 -- Client terminated, restarting in 2000 ms...
Again this is only happening while the device is connected to 4G. No issue when it is connected to WiFi.
Any idea what is happening here?
Re: "Session invalidated: KEEPALIVE_TIMEOUT" or "Inactivity timeout (--ping-restart), restarting"
Post by thisjun » Mon Feb 04, 2019 6:48 am
Could you show the VPN server log?
