Hi All
straightforward scenario but I've spent hours on this without success
I have one server with 2 virtual hubs configured with secureNAT enabled and DHCP set with the below
virtual hub1
192.168.30.1 - 192.168.50.200
virtual hub2
192.168.100.30 - 192.168.100.200
I want to route between the 2 hubs using the Layer3 switch that I have configured with the below settings for the virtual interface
192.168.1.50.201 / 255.255.0.0
192.168.100.201 / 255.255.0.0
the L3 switch is started and online
From virtual hub1 I can ping 192.168.50.201 all fine
from virtual hub 2 I cannot ping 192.168.100.201 ???
I can see the interfaces created in the IP tables section on both hubs - see attachments
please any advice appreciated - this really seems quite forward without success
Layer 3 routing between hubs
ashah7
raafat
Re: Layer 3 routing between hubs
Hello there! Did you notice that you are using overlapping IP settings? Note that "192.168.50.201/255.255.0.0" overlaps with "192.168.100.201/255.255.0.0". But IP routing is involved in routing traffic between different IP subnets. Double check for that issue and try again.
Good luck
Good luck
