Connect to VPN Server through the VPN
marche
Is it possible to remotely connect to the VPN Server (and change settings) whilst connected through the VPN itself? It seems I cannot ping the server (in this case a raspberry pi) when I am connected to itself through SoftEther. I cant even SSH into the RPi. Is it possible to enable this?
sky59
Re: Connect to VPN Server through the VPN
For me it works like this:
I connect to server as vpn ....
Then i can ssh on axddess 192.168.4.1 that is my static address on server
raafat
You can't access the same IP address which SE listening on on unix-liked kernels. And Raspberry is not an exception to this. You could do it on Windows-based machines.
SoftEther VPN Server Manager can connect to the remote VPN server with listening TCP port of the VPN server.
cmd wh0ami
Im thinking you need to use the local loopback address (127.0.0.1) to ssh in. You also might need to change a setting in /etc/ssh/sshd_config to accept local loopback. Dont quote me on that though.
