Cannot connect to VPN server
moatazelmasry
Re: Cannot connect to VPN server
Post by moatazelmasry » Tue Oct 04, 2016 4:34 pm
Please have a look at the server logs of SE and add them here, specifically
server_log/
Also if you can, pleas recompile SoftEther using:
make DEBUG=YES
Then start SE as following:
./bin/vpnserver/vpnserver execsvc
Then initiate a connection from your windows client, then save the debug output into a file and paste it here as well
Cheers
Post by cedar » Tue Nov 01, 2016 7:36 am
IPsec server and client can't work on the same machine.
Please try another host as client.
