Different subnets on LAN to LAN VPN with L2 Bridge)
DrUnleavened
Post by DrUnleavened » Tue Jan 15, 2019 10:56 am
We are building a site to site VPN, though our router doesn't support IP routing. Therefore we have opted to using the L2 Bridge. My question is whether you can use this, and be able to give the different remote sites and the local site a different subnet such as 192.168.1.0/24 for the headquarter where the VPN server is and 192.168.2.0/24 for a remote location? As far as I understand this method makes the VPN server the DHCP server which can then give out IP addresses so this should be possible, right? Also, on the remote site I should disable the DHCP server as well, and then the VPN bridge will act like the DHCP server as well, and give out the IP addresses to the devices on the virtual hub? Please correct me if I misunderstand something. Thanks.
sky59
Re: Different subnets on LAN to LAN VPN with L2 Bridge)
Post by sky59 » Tue Jan 15, 2019 8:27 pm
Imagine lan cable = it is the same as L2 bridge.
If it would work with lan then also with SE, if not => not
DrUnleavened
Post by DrUnleavened » Wed Jan 16, 2019 11:52 am
I have written a much more detailed post including the current setup, please check that after it's approved.
Thanks.
