client with vlan id assigned by radius not getting IP address from DHCP secureNAT
ashah7
Post by ashah7 » Sat Jan 19, 2019 2:06 pm
I'm using Radius authentication with the Tunnel-Pvt-Group-ID attribute set to receive the vlan for the client from Radius.
The vlan specified is assigned all fine however now a dhcp address is not assigned to the client? (I'm using the onboard secureNAT
dhcp server to assign address)
please help
ashah7
Re: client with vlan id assigned by radius not getting IP address from DHCP secureNAT
Post by ashah7 » Sun Jan 20, 2019 1:29 am
any clues anyone?
Post by thisjun » Thu Feb 21, 2019 6:18 am
SecureNAT doesn't on the VLAN.
If you want to use SecureNAT, you should create another virtual hub and cascade connection with VLAN ID.
