Avoid Internet traffic trought VPN
ilNebbioso
Post by ilNebbioso » Sat Feb 02, 2019 11:42 pm
Hello!
I've got a succesfull PC-to-LAN configuratio which doesn't use SecureNAT: I can successfully remotely connect to the LAN.
But, all the Internet traffic generated from the remote PC goes trought the VPN tunnel instead of use the direct PC internet connection.
What I have to change in order to do this? I found a couple of links who says to change DHCP or PUSH commands, but I'm not sure what and where I have to change.
Somebody could help me?
Thank you!
Re: Avoid Internet traffic trought VPN
Post by thisjun » Thu Mar 28, 2019 5:48 am
Please try to set the interface metric value of the virtual NIC larger than the adapter that is used for the default gateway.
