Has anyone experienced settings to revert if there's been a powercut and the computer shuts down unexpectedly?
I'm using an Orange Pi Zero 512MB with Micro SSD (sandisk).
Config files keep their settings / data / etc but I've noticed that the Azure VPN changes to disabled and the Dynamic DNS loses the DNS entry I created, meaning I can't reuse the same DNS entry.
Chris
Losing Settings after Power Cut
cmpts_cpeacock
Re: Losing Settings after Power Cut
Could you check the permission of the directory?
