I'm desperating. My network-diagram looks like this:
And the cascade-connections work:
My aim is to connect between different SIDS (e.g. client 192.168.11.5 to 192.168.10.91). But it doesn't work. What do I have to do? Do I have to add routes?
Thank in advance
Can't connect between SIDs
vandergraf
vandergraf
Re: Can't connect between SIDs
I forgot to say, that the VPN-Server is 192.168.10.102
It is not possible to communicate directly between different broadcast domains.
Please refer to this document.
https://www.softether.org/4-docs/1-manu ... P_Routing)
