Neo6_x64 drivers fail Tests Windows 10 Server 2016 / 19
dvscomp
Post by dvscomp » Thu Mar 07, 2019 10:52 pm
We have had problems testing Softether on Windows Sever 2019 and windows 10 build 1809 with blue screen, so we have run the driver through the windows Hardware lab for testing and they have failed tests for windows 10 and above, is any one aware of the drivers not compatible with Windows 10 and Server 2016 / 2019? and is any one working on this issue ?
please see HLK report below
Neo6_x64_VPN testing report
Test configuration
Test playlist: Windows Hardware Compatibility Playlist
Test client machine:
• Windows 10 x64 1809
• VPN Client Adapter - Neo6_x64_VPN.sys v4.25.0.9658
• VPN Client - SoftEther VPN Client v4.29-9680 (to establish virtual test network connection for multiple machines NDIS tests)
Support machine:
• VPN Server - SoftEther VPN Server v4.29-9680 (to provide virtual test network)
Test network scheme
Machines are connected via Message Network (for testing software purposes) and Test Network (VPN).
Test Device on Test Client and Support Device on Support Machine represent installed device driver in test network.
Test results
Summarized list of tests with passed/failed markings
Passed NDISTest 6.5 - [2 Machine] - ConfigCheck
Passed DF - Embedded Signature Verification Test (Tuning and Validation)
Passed DF - InfVerif INF Verification
Failed DF - PNP Cancel Remove Device Test (Reliability)
Failed DF - PNP Cancel Stop Device Test (Reliability)
Passed DF - PNP DIF Remove Device Test (Reliability)
Failed DF - PNP Disable And Enable Device Test (Reliability)
Failed DF - PNP Rebalance Fail Restart Device Test (Reliability)
Failed DF - PNP Rebalance Request New Resources Device Test (Reliability)
Failed DF - PNP Remove Device Test (Reliability)
Failed DF - PNP Stop (Rebalance) Device Test (Reliability)
Failed DF - PNP Surprise Remove Device Test (Reliability)
Failed DF - Reinstall with IO Before and After (Reliability)
Failed DF - Sleep and PNP (disable and enable) with IO Before and After (Reliability)
Passed DF - Sleep with IO During (Reliability)
Passed HyperVisor Code Integrity Readiness Test
Passed NDISTest 6.0 - [1 Machine] - 1c_64BitOIDs
Passed NDISTest 6.0 - [1 Machine] - 1c_FaultHandling
Passed NDISTest 6.0 - [1 Machine] - 1c_IOCTLCoverage
Passed NDISTest 6.0 - [1 Machine] - 1c_KernelCalls
Passed NDISTest 6.0 - [1 Machine] - 1c_Mini6PerfSend
Passed NDISTest 6.0 - [1 Machine] - 1c_Mini6Send
Passed NDISTest 6.0 - [1 Machine] - 1c_NdisRequestCov
Passed NDISTest 6.0 - [1 Machine] - 1c_OidsDeviceIoControl
Passed NDISTest 6.0 - [1 Machine] - 1c_OidsWMI
Passed NDISTest 6.0 - [1 Machine] - 1c_Registry
Passed NDISTest 6.0 - [1 Machine] - 1c_WMICoverage
Passed NDISTest 6.0 - [2 Machine] - 2c_Mini6CheckConnections
Passed NDISTest 6.0 - [2 Machine] - 2c_Mini6Performance
Passed NDISTest 6.0 - [2 Machine] - 2c_Mini6SendRecv
Failed NDISTest 6.0 - [2 Machine] - 2c_Mini6SendRecvReply
Passed NDISTest 6.0 - [2 Machine] - 2c_Mini6Stress
Failed NDISTest 6.0 - [2 Machine] - 2c_OidsNdisRequest
Failed NDISTest 6.0 - [2 Machine] - 2c_Priority
Passed NDISTest 6.5 - [1 Machine] - GenericMiniportRequirements
Passed NDISTest 6.5 - [1 Machine] - OffloadParity
Failed NDISTest 6.5 - [1 Machine] - PM_Requirements
Passed NDISTest 6.5 - [1 Machine] - StandardizedKeywords
Failed NDISTest 6.5 - [2 Machine] - AddressChange
Passed NDISTest 6.5 - [2 Machine] - CheckConnectivity
Passed NDISTest 6.5 - [2 Machine] - CheckConnectivity with AutoFail
Passed NDISTest 6.5 - [2 Machine] - E2EPerf
Failed NDISTest 6.5 - [2 Machine] - GlitchFreeDevice
Passed NDISTest 6.5 - [2 Machine] - InterruptModeration
Failed NDISTest 6.5 - [2 Machine] - InvalidPackets
Failed NDISTest 6.5 - [2 Machine] - LinkCheck
Failed NDISTest 6.5 - [2 Machine] - MultiCast Address
Passed NDISTest 6.5 - [2 Machine] - OffloadMisc
Failed NDISTest 6.5 - [2 Machine] - PacketFilters
Passed NDISTest 6.5 - [2 Machine] - Reset
Failed NDISTest 6.5 - [2 Machine] - ShortPackets
Passed NDISTest 6.5 - [2 Machine] - SingleEtherType
Failed NDISTest 6.5 - [2 Machine] - Stats
Passed NDISTest 6.5 - [2 Machine] - TxFlowControl
Failed NDISTest 6.5 - [2 Machine] – VlanSendRecv
Test error details
1. New playlist provokes BSOD on some DF tests:
• DF - PNP Cancel Remove Device Test (Reliability)
• DF - PNP Disable And Enable Device Test (Reliability)
• DF - PNP Rebalance Fail Restart Device Test (Reliability)
• DF - PNP Rebalance Request New Resources Device Test (Reliability)
• DF - PNP Stop (Rebalance) Device Test (Reliability)
• DF - PNP Surprise Remove Device Test (Reliability)
• DF - Reinstall with IO Before and After (Reliability)
• DF - Sleep and PNP (disable and enable) with IO Before and After (Reliability)
2. NDISTest 6.0 - [2 Machine] - 2c_Mini6SendRecvReply with errors:
a. Some of the net buffers sent from Support card were corrupted during communication
b. Some of the net buffers sent from Test card were corrupted during communication
3. NDISTest 6.0 - [2 Machine] - 2c_OidsNdisRequest with error “Packets/bytes received statistics not as expecte”
4. NDISTest 6.0 - [2 Machine] - 2c_Priority with error “All drivers with NDIS Version greater than 5.1 must enable 802.1p by default and must report when queried for OID_GEN_MAC_OPTIONS”
5. NDISTest 6.5 - [1 Machine] - PM_Requirements - BSOD
6. NDISTest 6.5 - [2 Machine] – AddressChange – BSOD
7. NDISTest 6.5 - [2 Machine] – GlitchFreeDevice with errors
a. Adapter statistics indicate fewer packets sent than comm helper statistics.
b. Analyzer detected 288 errors with packets per DPC = 10
c. Analyzer detected 159 errors with packets per DPC = 100
d. Analyzer detected 147 errors with packets per DPC = 1000
e. 30 total breakpoints were hit in the protocol driver while this test was executing
8. NDISTest 6.5 - [2 Machine] – InvalidPackets with error “20 total breakpoints were hit in the protocol driver while this test was executing”
9. NDISTest 6.5 - [2 Machine] – LinkCheck with no error description
10. NDISTest 6.5 - [2 Machine] - MultiCast with error “Received less than the expected percentage of packets sent.”
11. NDISTest 6.5 - [2 Machine] – PacketFilters with error “Following probed filters do not match the advertised filter value: Multicast | AllMulticast | SourceRouting | Promiscuous | Smt | Group | Functional | MacFrame”
And error “0 packets expected but received 230 packets”
12. NDISTest 6.5 - [2 Machine] – ShortPackets with error “The miniport did not correctly pad all short packets. 40 incorrect packets.”
13. Failed NDISTest 6.5 - [2 Machine] – Stats with error “NDIS_STATISTICS_FLAGS_VALID_DIRECTED_BYTES_XMIT was not updated correctly”
14. Failed NDISTest 6.5 - [2 Machine] – VlanSendRecv - BSOD
Re: Neo6_x64 drivers fail Tests Windows 10 Server 2016 / 19
Post by cedar » Tue May 21, 2019 8:11 am
I think that it is better to post information on development on GitHub.
https://github.com/SoftEtherVPN/SoftEtherVPN/issues
