I have successfully created Softether server and can connect to it through CGNAT with windows PC, using the softether client, however i cannot connect to it with android (L2TP/IPSec PSK), i am guessing because this needs portforwarding, is there any alternative way i can connnect with android without portforwarding?? I am not very knowledgeable.
Thank you
How to connect android to softether without port forwarding (CGNAT)
danielmachado1999
Re: How to connect android to softether without port forwarding (CGNAT)
Port forwarding is required for L2TP / IPSec.
How about use VPS?
How about use VPS?
swahilli
Have the very same question.
Have couple of android devices which i need to VPN connect to a behind the ISP NAT SE VPN server running on Windows.
Is there any possible Android software utilising ative SE VPN or is there a way to make the task through VPN Azure?
Particularly i'm interested in any way of connecting from Android to home network without VPS,
