Hi
I successfully installed SoftEther on Linux Ubuntu VPS, and done the configuration based-on the docs.
But I can't connect to it (L2TP) singly. It shows Error. BTW, if I connect to another VPN server, it works and connects to SoftEther L2TP VPN.
Any idea would be helpful.
Can't connect to L2TP on Windows 10
Re: Can't connect to L2TP on Windows 10
Does the server listen the UDP port 500 and 4500?
