Hello!
My Physical Locations: HQ, Remote
My Virtual Hubs: HQ, Remote
HQ has a DHCP server which issues 192.168.1.0/24
Remote has a DHCP server which issues 192.168.0.0/24
If I connect to the virtual hubs with the SoftEther VPN Client, it works, meaning I can access all of my devices on that network. For example if I connect to the HQ virtual hub using the SoftEther VPN Client, I can see the website running on 192.168.1.10. If I connect to Remote, I can see the website running on 192.168.0.100.
^^ This is the current setup.
Now I would like to introduce a virtual layer 3 switch so that the devices on each physical network can see those in the other location, and the other way around. (Site to Site VPN), but I need your help setting it up.
What virtual interfaces and routing table entries do I have to define in order to achieve this?
Thank you.
HELP NEEDED WITH SITE TO SITE
Re: HELP NEEDED WITH SITE TO SITE
Did you check this manual?
https://www.softether.org/4-docs/1-manu ... P_Routing)
