have used Softether previous to connect my Iphone to my home network. This worked just fine.
I had to reinstall the computer the other day. And now I am not able to connect anymore: All I get is an error code 0 )No error - with no further explanation:
I have tried different settings with the same results
Any idea what could cause this?
File:
03-30 10:08:34.034 Connection "CID-34-A26EEF740C" has been terminated.
2019-03-30 10:08:34.034 The connection with the client (IP address 127.0.0.1, Port number 55084) has been disconnected.
2019-03-30 10:08:48.299 On the TCP Listener (Port 992), a Client (IP address 127.0.0.1, Host name "DESKTOP-FJTK71U", Port number 55085) has connected.
2019-03-30 10:08:48.299 For the client (IP address: 127.0.0.1, host name: "DESKTOP-FJTK71U", port number: 55085), connection "CID-35-DD8EDDB3E3" has been created.
2019-03-30 10:08:48.323 SSL communication for connection "CID-35-DD8EDDB3E3" has been started. The encryption algorithm name is "AES128-SHA".
2019-03-30 10:08:48.323 Connection "CID-35-DD8EDDB3E3": 0 Virtual Hub servers have been enumerated on this server.
2019-03-30 10:08:48.354 Connection "CID-35-DD8EDDB3E3" terminated by the cause "No error." (code 0).
2019-03-30 10:08:48.354 Connection "CID-35-DD8EDDB3E3" has been terminated.
2019-03-30 10:08:48.354 The connection with the client (IP address 127.0.0.1, Port number 55085) has been disconnected.
2019-03-30 10:08:53.914 On the TCP Listener (Port 992), a Client (IP address 127.0.0.1, Host name "DESKTOP-FJTK71U", Port number 55086) has connected.
2019-03-30 10:08:53.914 For the client (IP address: 127.0.0.1, host name: "DESKTOP-FJTK71U", port number: 55086), connection "CID-36-C0B5F04D88" has been created.
2019-03-30 10:08:53.938 SSL communication for connection "CID-36-C0B5F04D88" has been started. The encryption algorithm name is "AES128-SHA".
2019-03-30 10:08:53.938 Connection "CID-36-C0B5F04D88" connected using server admin mode.
2019-03-30 10:08:53.938 Connection "CID-36-C0B5F04D88" successfully logged in using administration mode.
2019-03-30 10:08:53.938 Connection "CID-36-C0B5F04D88" created a new remote procedure call session "RPC-2988" for the purpose of administration mode.
2019-03-30 10:10:32.047 Connection "CID-36-C0B5F04D88" terminated by the cause "No error." (code 0).
2019-03-30 10:10:32.047 Connection "CID-36-C0B5F04D88" has been terminated.
2019-03-30 10:10:32.047 The connection with the client (IP address 127.0.0.1, Port number 55086) has been disconnected.
2019-03-30 10:10:34.063 On the TCP Listener (Port 992), a Client (IP address 127.0.0.1, Host name "DESKTOP-FJTK71U", Port number 55091) has connected.
2019-03-30 10:10:34.063 For the client (IP address: 127.0.0.1, host name: "DESKTOP-FJTK71U", port number: 55091), connection "CID-37-48CEA0341E" has been created.
2019-03-30 10:10:34.087 SSL communication for connection "CID-37-48CEA0341E" has been started. The encryption algorithm name is "AES128-SHA".
2019-03-30 10:10:34.087 Connection "CID-37-48CEA0341E": 0 Virtual Hub servers have been enumerated on this server.
2019-03-30 10:10:34.119 Connection "CID-37-48CEA0341E" terminated by the cause "No error." (code 0).
2019-03-30 10:10:34.119 Connection "CID-37-48CEA0341E" has been terminated.
2019-03-30 10:10:34.119 The connection with the client (IP address 127.0.0.1, Port number 55091) has been disconnected.
2019-03-30 10:10:40.934 On the TCP Listener (Port 992), a Client (IP address 127.0.0.1, Host name "DESKTOP-FJTK71U", Port number 55092) has connected.
2019-03-30 10:10:40.934 For the client (IP address: 127.0.0.1, host name: "DESKTOP-FJTK71U", port number: 55092), connection "CID-38-B2650792B4" has been created.
2019-03-30 10:10:40.958 SSL communication for connection "CID-38-B2650792B4" has been started. The encryption algorithm name is "AES128-SHA".
2019-03-30 10:10:40.958 Connection "CID-38-B2650792B4": 0 Virtual Hub servers have been enumerated on this server.
2019-03-30 10:10:40.998 Connection "CID-38-B2650792B4" terminated by the cause "No error." (code 0).
2019-03-30 10:10:40.998 Connection "CID-38-B2650792B4" has been terminated.
2019-03-30 10:10:40.998 The connection with the client (IP address 127.0.0.1, Port number 55092) has been disconnected.
2019-03-30 10:10:49.987 On the TCP Listener (Port 443), a Client (IP address 127.0.0.1, H
Code 0
Re: Code 0
It seems that these logs isn't access from iphone.
Please check port-forwarding configuration on your router.
