I have installed softether on my home server (actually in a chroot environment, which I added to my Zyxel NAS). I use the openVPN-mode and connections from outside work fine.
However, I found out that I can access all machines in my local net using the vpn, but not the machine softether is running on. Thats a pity because its the NAS with all my files on.
I found a discussion on this topic wehere it is explained, that this is a given limitation of te linux kernel. As a workaround, a tun-device could be used:
https://github.com/SoftEtherVPN/SoftEtherVPN/issues/298
However, as I am running softether in a chroot environment, i am not able to define a tun-device. I think the reason is, that the kernel does not have the needed module.
Is there another way to allow of the server itself via vpn?
Regards,
jba
Cannot access server using vpn
brentnickel
Re: Cannot access server using vpn
I have same problem!
There is a limitation of localbridge on Linux.
https://www.softether.org/4-docs/1-manu ... r_Mac_OS_X
