Vpn on demand
bong.mau
Vpn on demand
Post by bong.mau » Wed May 01, 2019 7:11 am
Hi
finally i succesfully installed on my win xp sp3 machine vpn client,i'm able to connect and all work fine
I need to activate vpn on demand so i disabel it at startup using msconfig
when i enable it again i get "unable to connect to the vpn client service operating on local computer
make sure the vpn client service has started and running normally"
task manager shows vpnclient and vpncmgr in execution
i tryed also to start it manually going into directory and run
vpncmgr /setup
vpnclient /uihelp
but when i stat vpncmgr again to start connection i get again the message
i think is a bug
Maurizio
bong.mau
Re: Vpn on demand
Post by bong.mau » Wed May 01, 2019 7:13 am
i'm running softether 2019.04.30 build 9680 144132
Re: Vpn on demand
Post by cedar » Wed Jun 05, 2019 6:53 am
You do not need the UI helper on Windows XP.
Is the system service vpnclient running?
