Hello, I have installed SoftEther VPN Server on a pfSense box (FreeBSD).
My ISP changed my public IP recently but vpnXXX.softether.net still points to an old IP.
The problem is when I connect to my server and run a command DynamicDNSGetStatus there is an error code 33.
Unsupported.
What should I do to make it running?
DynamicDNS not working
Driver
Re: DynamicDNS not working
ok I figured it out:
need to change in vpn_server.config file:
to:
declare DDnsClient
bool Disabled true
}Code: Select all
declare DDnsClient
bool Disabled false
