I'm trying to configure OpenVPN to connect to SoftEther server with certificate but it not works:
ovpn file:
dev tun
proto udp
remote xx.xx.xx.xx 1194
cipher AES-128-CBC
auth SHA1
resolv-retry infinité
bobine
persist-key
persist-tun
client
verb 3
key user1.key
cert user1.crt
<ca>
</ca>
<cert>
</cert>
<key>
</key>
Tue May 21 18:06:09 2019 OpenVPN 2.4.3 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jul 14 2017
Tue May 21 18:06:09 2019 Windows version 6.2 (Windows 8 or greater) 64bit
Tue May 21 18:06:09 2019 library versions: OpenSSL 1.0.2l 25 May 2017, LZO 2.10
Enter Management Password:
Tue May 21 18:06:09 2019 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340
Tue May 21 18:06:09 2019 Need hold release from management interface, waiting...
Tue May 21 18:06:09 2019 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25340
Tue May 21 18:06:09 2019 MANAGEMENT: CMD 'state on'
Tue May 21 18:06:09 2019 MANAGEMENT: CMD 'log all on'
Tue May 21 18:06:09 2019 MANAGEMENT: CMD 'echo all on'
Tue May 21 18:06:09 2019 MANAGEMENT: CMD 'hold off'
Tue May 21 18:06:09 2019 MANAGEMENT: CMD 'hold release'
Tue May 21 18:06:09 2019 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Tue May 21 18:06:09 2019 TCP/UDP: Preserving recently used remote address: [AF_INET]xx.xx.xx.xx:1194
Tue May 21 18:06:09 2019 Socket Buffers: R=[65536->65536] S=[65536->65536]
Tue May 21 18:06:09 2019 UDP link local: (not bound)
Tue May 21 18:06:09 2019 UDP link remote: [AF_INET]xx.xx.xx.xx:1194
Tue May 21 18:06:09 2019 MANAGEMENT: >STATE:1558454769,WAIT,,,,,,
Tue May 21 18:06:09 2019 MANAGEMENT: >STATE:1558454769,AUTH,,,,,,
Tue May 21 18:06:09 2019 TLS: Initial packet from [AF_INET]xx.xx.xx.xx:1194, sid=1ffc44a1 b9e26d39
Tue May 21 18:06:10 2019 VERIFY OK: depth=0, CN=xxx.softether.net, O=xxx.softether.net, OU=xxx.softether.net, C=US
Tue May 21 18:06:10 2019 Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 2048 bit RSA
Tue May 21 18:06:10 2019 [xxx.softether.net] Peer Connection Initiated with [AF_INET]xx.xx.xx.xx:1194
Tue May 21 18:06:11 2019 MANAGEMENT: >STATE:1558454771,GET_CONFIG,,,,,,
Tue May 21 18:06:11 2019 SENT CONTROL [xxx.softether.net]: 'PUSH_REQUEST' (status=1)
Tue May 21 18:06:11 2019 AUTH: Received control message: AUTH_FAILED
Tue May 21 18:06:11 2019 SIGUSR1[soft,auth-failure] received, process restarting
Tue May 21 18:06:11 2019 MANAGEMENT: >STATE:1558454771,RECONNECTING,auth-failure,,,,,
Tue May 21 18:06:11 2019 Restart pause, 5 second(s)
Thank you.
