How disable Aggressive IKE Mode
robymos
Post by robymos » Thu Jun 06, 2019 1:14 pm
Hi everyone !
After googling everywhere for a solution to my question, I try in this forum.
I'd like to disable Aggressive IKE mode (for security purposes) but, even if I have installed the last version of Windows SoftEther VPN Server (Ver 4.29, Build 9680) I don't find where this option is... maybe it isn't present in GUI interface ?
Can you help me ?
Thank you in advance !
Greetings
Robymos
Re: How disable Aggressive IKE Mode
Post by thisjun » Tue Jun 18, 2019 5:15 am
drnoelkelly
Post by drnoelkelly » Fri Apr 03, 2020 2:27 pm
"Added the DisableIPsecAggressiveMode option. You can set "bool DisableIPsecAggressiveMode true" to disable the IPsec Aggressive Mode to moderate CVE-2002-1623."
dha76
Post by dha76 » Thu Jun 23, 2022 12:00 pm
Where on the server side is the "bool DisableIPsecAggressiveMode true" meant to be set?
Post by solo » Thu Jun 23, 2022 12:19 pm
stop the server
edit vpn_server.config
start the server
