SoftEther VPN at Windows Login Screen
nextflight19
Post by nextflight19 » Sat Jun 08, 2019 9:56 pm
When a user turns on their computer that has Windows 7 or Windows 10 in a AD domain, is there a way to configure SoftEther so that when the OS is at the login screen for Windows that you would be able to select the VPN client first to have the computer authenticate with AD, so that the user can login with AD credentials (as if the user was working remote from the office).
centeredki69
Re: SoftEther VPN at Windows Login Screen
Post by centeredki69 » Sun Jun 09, 2019 6:20 pm
The SE client will RUN as a service. In the SE client you can choose a connection to be set as a startup connection. The SE client service will try auto connect to the assigned VPN during startup even before the person logs in.
