Disable Softether welcome web page
dev
Post by dev » Sun Jul 07, 2019 5:20 pm
My ISP blocks VPN connections via DPI (deep packet inspection) and IP ban lists.
Softether seems to be really good at evading DPI, but it has a glaring omission that it displays a welcome web page for everyone to see, declaring itself to be a VPN server. Which is very easy for my ISP to detect and ban.
How do you disable this landing / welcome web page?
I've tried modifying vpn_server.config to change the following line:
bool DisableJsonRpcWeb.Api fale
to
bool DisableJsonRpcWeb.Api true
then restarted, but that didn't do it. The page still up.
Any idea how to stop this page from showing to everyone visiting my Softether VPN address via https://myvpnaddress ?
centeredki69
Re: Disable Softether welcome web page
Post by centeredki69 » Mon Jul 08, 2019 10:18 pm
What welcome web page are you talking about? I have never been re-routed to a "SoftEther Welcome web page" when I connect to a VPNGATE or a SoftEther server. Are you talking about the little popup you sometimes get when connecting to a "VPNGATE server" If so that is controlled on the host server and is not a webpage.
ciscozine
Post by ciscozine » Sun Oct 27, 2019 8:54 pm
Hi @centeredki69,
I have the same problem. Have you find how to disable the web page?
thanks
ozone
Post by ozone » Sun Nov 03, 2019 5:17 am
I don't know if you need the possibility to administer the SE server remotely, but if -not- , you could use the adminip.txt to specify from which ip someone can administer the SE-server.
It doesn't kill the welcome page (contrary to what the line "•If you want to disable this embedded web server and JSON-RPC server" might suggest), but at least it seems to disable the admin part.
For the record... as it is now, this welcompage is one of the worst ideas ever: This welcomepage is always visible and cannot be disabled on the port you open the SE server to the world!!!
It has been mentioned many times in the forum that this page should only be visible AFTER successful authentication, and preferably also only to addresses in the adminip.txt.
Please dnobori: Remove this "feature" asap. This is a serious security issue, even without DPI.
Oz
timar.david
Post by timar.david » Sun Nov 10, 2019 2:48 pm
Hi All,
I think it's a very important issue. This web page gives out to much information to the world. I think that if you set"DisableJsonRpcWebApi" to true then the built in web admin console wouldn't ask for authentication any more, but gives out a "The requested URL /admin/ was not found on this server."
But right under it, there is the internal IP address of the server.
So I would very appreciate it if this whole web page could be disabled. Anybody know how to edit maybe the html page to this site?
Thank you.
Dávid
ciscozine
Post by ciscozine » Sun Nov 10, 2019 5:01 pm
I think the only solution is compile source code removing the index.html page but I didn't test it.
gg_user
Post by gg_user » Fri Nov 15, 2019 9:45 am
It is a very bad idea to have vpn server turned on by default
web server! This will lead to hacking vpn.
It is necessary to enable the administrator to completely disable the web server.
lovether
Post by lovether » Fri Nov 15, 2019 5:45 pm
You can use unstable version 5.01.9671 which has fixed the problem.
ozone
Post by ozone » Thu Nov 28, 2019 8:26 am
Thank you for the link Lovether.
Wasn't aware that there existed a branch that already fixed it.
I also see a new release from Dnobori, which also hints to a fix.
Oz.
