VPN is slow
cbarr
VPN is slow
Post by cbarr » Fri Aug 02, 2019 8:54 pm
We have a server on a domain that is setup with SoftEther using the Azure VPN connect. Setting it up was easy enough and connecting via remote works but the speeds are slow. This is setup for a client who uses RDP so we are putting VPN in front of it. Ideas?
sky59
Re: VPN is slow
Post by sky59 » Sat Aug 03, 2019 4:56 am
Yest it is slow over azure by principle
