Hello guys! When you have open 443 port for vpn client connection you also have this page, which clearly indicates which software is running:
How can i modify/remove it?
SoftEther VPN Server / Bridge
For VPN users:
    Connect to this VPN Server
        by Official SoftEther VPN Client (download)
        by L2TP/IPsec, OpenVPN or SSTP traditional clients
For VPN administrators:
    Manage this VPN Server or VPN Bridge
        by SoftEther VPN Server Manager GUI for Windows / macOS (download) (Recommended)
        by SoftEther VPN Command Line Management Utility (vpncmd) for CUI
        by JSON-RPC API from your favorite programming language (JavaScript, TypeScript, Java, Python, Ruby, C#, ... etc.)
        (ID: 'administrator', Password: same to the VPN Server's password. Default: empty)
        by Built-in HTML5 Web Administration Console (New, under construction)
    If you want to disable this embedded web server and JSON-RPC server:
        Stop the daemon.
        Modify the value of "bool DisableJsonRpcWebApi" from "false" to "true" on the vpn_server.config or vpn_bridge.config.
        Restart the daemon.
