VPN cannot be used in China
rhasv
Post by rhasv » Thu Aug 29, 2019 4:40 pm
All servers cannot connect
myron@co-hop.uk
Re: VPN cannot be used in China
Post by myron@co-hop.uk » Mon Sep 16, 2019 7:23 pm
I personally don't know how to do this, but I am wondering if it is possible to create a VPN connection through the TOR network.
sky59
Post by sky59 » Tue Sep 17, 2019 4:03 am
So all servers are down?
It is impossible to block SE on port 443
if you need help you must write what client you use. If you use openvpn or builtin adroid vpn it is blocked - do not use 443 port
Do not cry 'all server cannot connect' write what you use and solve the problem yourself!
hkg.cnn
Post by hkg.cnn » Tue Sep 17, 2019 9:06 am
Suppose your IPs of server are being blocked. So you need to change the IPs for servers or get the new servers and IPs.
Who have ideas or solutions for unsuccessful L2TP connection to Softether VPN server in China? All L2TP IPsec/PSK connections from iPhone, Android, and Macbook are unsuccessful from China. It should be blocked by China GFW. Please advise. Thanks!
Pony
sky59
Post by sky59 » Tue Sep 17, 2019 12:32 pm
You can not read?!
Use SoftEther https protocol on port 443. This is impossible to block.
I made my own compilation of SEclient for android - search this forum.
hkg.cnn
Post by hkg.cnn » Thu Sep 19, 2019 2:28 am
I have searched the forum and seen there are some discussions about SEClient for Android. No attahment or app for download...
Could you please upload SEClient for Android here? Thanks!
sky59
Post by sky59 » Thu Sep 19, 2019 7:38 am
App does not exist. I start it manually on tablet. Tablet must be rooted to be able to run it.
If you are really interested try if you are able to connect from any linux machine starting it manually. It is the same process.A bit complicated.
The most complicated was to configure the vpn client. I used usb-LAB converter and used PC based manager to configure it.
If you try linux machine it is easier to configure because then you can connect PC machine with manager to any LAN interface.
Then if you succed you can use configuration file direclty for Android - vpn_client.config
sky59
Post by sky59 » Fri Sep 20, 2019 8:57 am
Try first if you are able to run vpncmd on your tablet.
Download it here: (change to english flag)
https://uloz.to/file/s0e2iS8gVfrh/vpncmd-zip
Dvorak
Post by Dvorak » Fri Sep 20, 2019 1:02 pm
What does vpncmd do exactly when you run it on a tablet anyway?
sky59
Post by sky59 » Fri Sep 20, 2019 3:56 pm
It runs in terminal window asking you first question what you want and then another questions.....
Just type help
shivangi
Post by shivangi » Fri Oct 04, 2019 9:44 am
I just googled it that using a VPN can cause a fine of $145 there.
sky59
Post by sky59 » Sat Oct 05, 2019 10:02 am
These are not rules and MUST not be obeyed
I can do what I want
abakus
Post by abakus » Thu Oct 10, 2019 6:44 pm
Read this topic:
https://www.vpnusers.com/viewtopic.php?f=7&t=64503
SE servers can be easily detected by your government. So it looks like they block se vpn servers by IP.
87502560
Post by 87502560 » Fri Oct 11, 2019 1:26 pm
do you use line? may i add your line ?
i am in China
fenice
Post by fenice » Fri Oct 11, 2019 1:30 pm
That's not, strictly speaking, true and one of the things you shouldn't do is to post duplicates in the forums. I've removed your duplicate post that you put up earlier.
Regards
Bill
sky59
Post by sky59 » Fri Oct 11, 2019 3:50 pm
I did not post twice, it is se-forum-server problem that it went out twice
And I am free person I can do what I want (except committing crimes)
fenice
Post by fenice » Fri Oct 11, 2019 5:20 pm
I've never seen that on these forums before nor in the fourteen years I've been using the forum software used here.
Not when you're posting in someone else's territory.
Regards
Bill
sky59
Post by sky59 » Fri Oct 11, 2019 5:25 pm
What are the time stamps for two posts?
