VPN Server>bridgedevicelist
BridgeDeviceList command - Get List of Network Adapters Usable as Local Bridge
net0
VPN Server>bridgelist
BridgeList command - Get List of Local Bridge Connection
Number|Virtual Hub Name|Network Adapter or Tap Device Name|Status
1 |DEFAULT |net0 |Error
VPN Server>
./vpncmd /SERVER localhost /CMD BridgeCreate DEFAULT /Device:net0 /TAP:no
./vpncmd /SERVER localhost /CMD IPsecEnable /L2TP:yes /L2TPRAW:no /ETHERIP:no /PSK:psk /DEFAULTHUB:DEFAULT
./vpncmd /SERVER localhost /HUB:DEFAULT /CMD SecureNatEnable
This is all I see in the logs:
2019-09-05 05:20:33.654 Administration mode [RPC-41]: The Local Bridge connection definition "DEFAULT" --> "net0" has been added.
2019-09-05 05:20:33.654 [HUB "DEFAULT"] The Local Bridge connection "net0" has started. The bridge session "SID-LOCALBRIDGE-1" was created.
2019-09-05 05:20:33.684 Connection "CID-2" terminated by the cause "No error." (code 0).
2019-09-05 05:20:33.684 Connection "CID-2" has been terminated.
